Help With Postproccesor
Discussion in 'OpenBuilds Forum Help' started by Nils Pettersson, Oct 29, 2024.
  1. Nils Pettersson
    Hi. Im pretty new at this and my ratrig 1515 is strugeling. Sometimes when im milling it makes weird movements from nowehere. often in complex pockets. I use fusion 360 and svg files. I run the GRLB/BlackBox PostV1.0.42. I also use duet 3 and raspberry pi.
    What is the problem Pls help me!
    /Nils
    Try a DUET Post - different controller, different dialect, it doesn't run Grbl.
  3. Alex Chambers
    If you are using the Duet controller there's a post processor (tested with the Duet 2) here -
    https://m.facebook.com/groups/workbeecncusersgroup/permalink/2888969308010998/
    You will have to join the Facebook group to download that.
    Or there's a more basic version (also intended for the Duet 2) on the Ooznest Learning Portal.
