how to build software on windows 10 ?
Discussion in 'Control Software' started by witawat, Oct 21, 2022.
  1. witawat
    witawat New
    Step run software and compile for windows10
    Maybe you need edit some option or function..
    Step compile for windows10
    1. download last version from GitHub and extract to you drive
    2 open windows terminal in folder and use command
    Code:
    npm install --global yarn
    yarn
    yarn electron-builder
    3 see exe file in folder
    Step for run dev mode edit some function and test
    Code:
    yarn electron-rebuild
    yarn electron .
    done..
    #1 witawat, Oct 21, 2022
  3. witawat
    witawat New
    Code:
    ./node-modules/.bin/electron .
  5. witawat
    witawat New
    can't run is not a valid Win32 application. or Error: Module did not self-register:
    Code:
    D:\Witawat_data\CNC\OpenBuilds-CONTROL-1.0.332>yarn electron .
    yarn run v1.22.19
    $ D:\Witawat_data\CNC\OpenBuilds-CONTROL-1.0.332\node_modules\.bin\electron .
    App threw an error during load
    Error: Module did not self-register: '\\?\D:\Witawat_data\CNC\OpenBuilds-CONTROL-1.0.332\node_modules\drivelist\build\Release\drivelist.node'.
        at process.func [as dlopen] (electron/js2c/asar.js:140:31)
        at Object.Module._extensions..node (internal/modules/cjs/loader.js:1034:18)
        at Object.func [as .node] (electron/js2c/asar.js:140:31)
        at Module.load (internal/modules/cjs/loader.js:815:32)
        at Module._load (internal/modules/cjs/loader.js:727:14)
        at Function.Module._load (electron/js2c/asar.js:769:28)
        at Module.require (internal/modules/cjs/loader.js:852:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at bindings (D:\Witawat_data\CNC\OpenBuilds-CONTROL-1.0.332\node_modules\bindings\bindings.js:112:48)
        at Object.<anonymous> (D:\Witawat_data\CNC\OpenBuilds-CONTROL-1.0.332\node_modules\drivelist\js\index.js:25:27)
    Terminate batch job (Y/N)? Y
    #5 witawat, Oct 21, 2022
  6. witawat
    witawat New
    Precompiled versions are available on
    Https://software.penbuilds.com - ready to run
    Your error shows you have not run electron-rebuild to rebuild dependencies like node-serialport and drivelist for electron. You'd have to spend a little time working through the electron documentation, we use the standard electron stack.
    Rebuilding of native modules: see Native Node Modules | Electron
  8. witawat
    witawat New
    thankyou now i can run software and try dev or edit some function
