Lines in my carvings on Lead 1010
Discussion in 'CNC Mills/Routers' started by Bruce Murphy, Apr 12, 2020.
  1. Bruce Murphy
    Good Evening,
    Can anyone tell me why I am getting the lines from corner to corner in my carvings? What am I doing wrong? 20200412_153419.jpg 20200412_153433.jpg 20200412_153419.jpg
  2. Gary Caruso
    Hi Bruce, Please post the cnc file here so we can help, what programs are you using?
    Is this the first 3D project you tried? has this happened on other projects?
    Gary
  3. David the swarfer
    I think backlash, cut some circles to check
  4. Bruce Murphy
    Using V-carve desktop and openbuilds control. I have done 3 or 4 3D projects and they all have done this.
    See uploaded files
    Thanks,
    Bruce
  5. Bruce Murphy
    I will check into the backlash this evening any thiing in particular I should look for? Am new to CNC
    Thanks,
    Bruce
  6. David the swarfer
    cut a circle, look for out of round and/or steps where X or Y change direction.
    once you know which axis it is (could be both) figure out what is loose and fix it. (-:
    discussed many times here in the forums, just search for the established answers
  7. Bruce Murphy
    Not sure what to look for posted some photos below. What do you see?
