Motor doesn’t always engage on startup
Discussion in 'CNC Mills/Routers' started by Bferster, Sep 3, 2022.
  1. Bferster
    Bferster Well-Known
    I use a black box controller for my 1010 style CNC with dual motors on the y axis. Every fourth time or so when I start, the left motor is not engaged, only the right. I can turn it with my fingers.
    When I power off and on, it re engages.
    Any ideas!
  2. sharmstr
    Peter Van Der Walt and Bferster like this.
    Labor day long weekend, so more likely Tuesday :)
    That said, returns for driver issues are very rare. More likely wiring on my bets, secondly Fault indicator.
  4. Bferster
    Bferster Well-Known
    The the fault indicator is indeed on. What does that mean?
    Should I up the current or pare it down, or is it some other issue?
    Bferster likes this.
  6. Bferster
    Bferster Well-Known
    Another thought. I turn the back box and power supply together. Should I be turning on the power supply first, then the controller?
    Normally yes, otherwise PSU might still be ramping up
  8. Bferster
    Bferster Well-Known
    I’ll try that and see if it fixes it. Thanks!
