Need Time Belt for X Axis on CNC Gantry
Discussion in '3D printers' started by Rene Rodriguez, Apr 8, 2020.
  1. Rene Rodriguez
    Hi,
    Hope this is the right forum space to post this question. I'm trying to replace the time belt for the x axis on our
    old custom built CNC. I is a white rubber and fiberglass belt that needs to be cut at approx 130" long and has a pitch of about 5.5 MM and a width of about 23 - 24 mm. I have been looking around for a supplier of these belts without success... Any feedback is greatly appreciated. Attached is a photo of the belt.
    Have you tried sdp-si.com or bbman.com?
  3. Gary Caruso
    Try this? Ebay link hard to say without a side shot and accurate measurement, couple different standards out there.
    Are the belt teeth flat on top or totally curved and round on the teeth?
    Gary
  4. Rene Rodriguez
    The teeth are flat on top and curved on the groove. I re measured it and it has a pitch of 5mm, the width is 26mm.. I'm attaching a side photo. Thanks for your help! 20200408_175719.jpg
  5. Rene Rodriguez
    Thank you.. will look at the link.
  6. Gary Caruso
    Are you sure its not 25mm? 25 would work even if it was 26.
    I actually have some 10mm wide belt just like that, I use at work, I looked up the part number and it's AT5 timing belt. Make sure to pick the AT5 and NOT the T5.
    Here you go on ebay
    Gary
  7. Rene Rodriguez
    Thank you!.. Will order, will let you know results.. thanks again for the tip!
