New machine ignores extension limit switches when homing
Discussion in 'General Electronics' started by Gizmo6, Jun 1, 2025.
  1. Gizmo6
    Gizmo6 New
    I just assembled a new machine and it does not stop either axis when the limit switches are contacted during homing.
    Manually tripping the switches works as expected, hard limit warning is produced and machine stops.
    When using home all the limit switches are ignored and the steppers continue attempting to move the axis until emergency stop is activated.
    What am I missing here?
  2. Alex Chambers
    Are you sure that the MACHINE is triggering the switches (problem with alignment?)
    Use Troubleshooting tab to test the switches, both a) that they all work and b) each switch is plugged into correct axis (pressing Z switch shouldn't light up X for example)
  4. Gizmo6
    Gizmo6 New
    Some bonehead swapped axis, all good now, thank you for the assistance.
