OB Blackbox issues ?
Discussion in 'General Talk' started by Mallardduck31, Dec 22, 2020.
  1. Mallardduck31
    I have run flawlessly for months with the Blackbox using the OB control. Yesterday I started getting odd error messages when running my surface zero macro. When initiated it would go into a lock out state and I would be forced to hit OK and then run the macro a second time and it would work. I did not capture the error message. This happened dozens of time throughout the day.
    Today, the motion in Both X and Y are not working properly. When trying to jog in either direction the motors stall. I have been able to get it to work but had to go in and change my Grbl $110 from 4000 to 2000 mm/min and $111 from 4500 to 2000.
    is the Blackbox going bad???
    Any help would be appreciated.
    Can you jot them down - each different error message offers clues to exact causes
    Without knowing what the errors were that led to Grbl being in an Alarm state (and thus locked out) - it would be hard to offer more information
    Any chance the power supply started failing? - measure output while a job is running, see if it dips below 24v under load
    Any other changes, Grbl settings corruption? Or changes that was applied? - adjusting acceleration to be more aggressive can lead to stalling for example
  3. Mallardduck31
    I my mistake on not capturing the codes. Will do that next time I see them.
    I just checked the power supply output. It is 24 volt at rest and then will bounce back and forth between 23.5 and 24 when running a gcode.
    Sounds OK :)
    Do check if your Grbl settings changed too.
  5. Mallardduck31
    I’m not seeing anything out of the ordinary. Acceleration is at 100 mm/sec2 for each axis. That’s where I have had them for months.
  6. Mallardduck31
    Ok. No error message this time but when I initiated the z zero macro the z axis shot down at max speed and slammed into the probe. Nothing broke since it stopped when making contact however the work coordinate position read 528mm. Normally it’s 42.
    when initiated the second time it went nice and slow just like always and zeroed correctly.
    I am baffled.
    What's in your Macro?
    We have setzero buttons in CONTROL, why are you using a Macro?
  8. Mallardduck31
    Haven’t changed over I guess. I’ve been using the same macro for almost a year.
  9. Peter Van Der Walt
    Yes but what commands are in your macro :) just so we can see if the earlier info could be explained
  10. Mallardduck31
    Here it is. I think you helped me write this one a while back.
  11. Peter Van Der Walt
    Yes newer versions have a much better Probe Wizard, please do use that instead:
    Are you by any chance using a very long USB cable / extra Extenders or hubs between computer and controller (serial corruption)
  12. David the swarfer
    unexplained speed and distance in the probe indicates a USB corruption or inch mode instead of mm.
    put a G21 at the start of the macro to make sure we get what we expect.
    also, that macro should have a G91 at the start so that the probe runs relative to the current position
  13. Mallardduck31
    I will make the
    Thanks for the info on the macro. I will make that change just in case I use it again as I transition to the OB probe wizard.
    The USB cable is 3-5 footer. Do the go bad over time?
  14. Peter Van Der Walt
    Not really no, as long as its a good quality cable, shorter = better
    As explained here docs:blackbox:faq-emi [OpenBuilds Documentation]
  15. Mallardduck31
    I went ahead and changed the USB cable out since I had a new one. It’s 4 feet.
  16. Mallardduck31
    Do we have any idea why the speed of movement had to be changed in the settings for the unit to function correctly after months of great service?
  17. Peter Van Der Walt
    Something binding up from cutting dust settling on moving parts? Do an inspection of your mechanical components
  18. Mallardduck31
    I did a complete cleaning and inspection yesterday and did not find anything. If this were the problem It would be very odd to have both the X and Y show the same problem. That’s why I’m leaning towards electrical issues. Is it possible the muscle board is bad?
  19. Mallardduck31
    This morning I’m getting this error when using the surfacing wizard.
    See attachment
  20. Mallardduck31
    Looks like there was a space in front of the 2mm depth when input into the wizard. All resolved.
  21. Peter Van Der Walt
    Bad muscle = no movement at all
    We've never seen one slowing down - that usually points to a settings/mechanical issue.
    In particular the odds of 2x Y and 1x X driver having the same issue is extremely remote. Stepper drivers tend to fail one at a time if they do. That was why I enquired about the PSU earlier.
    #21 Peter Van Der Walt, Dec 24, 2020
  22. Mallardduck31
    Here is a video at 2000mm/sec2 in Y and a second one at 3000 mm/sec2.
    the results are the same in both X and y.
    Prior to the issue starting two days ago I was running with both settings at 4000 without issue.
  23. Peter Van Der Walt
    Paste all the grbl settings please
  24. Peter Van Der Walt
    Grbl Settings > Backup Settings
    Open the file and paste content as text please :)
  25. Mallardduck31
    Sorry about that. Here you go.
    $0=248 ; Step pulse time, microseconds
    $1=255 ; Step idle delay, milliseconds
    $2=0 ; Step pulse invert, mask
    $3=0 ; Step direction invert, mask
    $4=1 ; Invert step enable pin, boolean
    $5=0 ; Invert limit pins, boolean
    $6=0 ; Invert probe pin, boolean
    $10=1 ; Status report options, mask
    $11=0.020 ; Junction deviation, millimeters
    $12=0.002 ; Arc tolerance, millimeters
    $13=0 ; Report in inches, boolean
    $20=0 ; Soft limits enable, boolean
    $21=1 ; Hard limits enable, boolean
    $22=1 ; Homing cycle enable, boolean
    $23=3 ; Homing direction invert, mask
    $24=100.000 ; Homing locate feed rate, mm/min
    $25=1000.000 ; Homing search seek rate, mm/min
    $26=250 ; Homing switch debounce delay, milliseconds
    $27=5.000 ; Homing switch pull-off distance, millimeters
    $30=1000 ; Maximum spindle speed, RPM
    $31=0 ; Minimum spindle speed, RPM
    $32=1 ; Laser-mode enable, boolean
    $100=197.855 ; X-axis steps per millimeter
    $101=197.941 ; Y-axis steps per millimeter
    $102=199.463 ; Z-axis steps per millimeter
    $110=2000.000 ; X-axis maximum rate, mm/min
    $111=3000.000 ; Y-axis maximum rate, mm/min
    $112=2000.000 ; Z-axis maximum rate, mm/min
    $120=100.000 ; X-axis acceleration, mm/sec^2
    $121=100.000 ; Y-axis acceleration, mm/sec^2
    $122=150.000 ; Z-axis acceleration, mm/sec^2
    $130=790.000 ; X-axis maximum travel, millimeters
    $131=760.000 ; Y-axis maximum travel, millimeters
    $132=190.000 ; Z-axis maximum travel, millimeters
  26. sharmstr
    Why is $0 so big? Shouldn't it be around 10?
  27. Peter Van Der Walt
    Grbl default is 10, see gnea/grbl
    This will slow you down a lot, delaying the step signal 24x longer than needed. BlackBox fine, Grbl Settings the root cause :)
    Laser mode is on, is it a laser machine?
    Grbl default is 0.010, see gnea/grbl
    Should be able to do 5000 or more after fixing $0
    Keep Z max rate lower, routers are heavy, gravity works in the vertical axis
    Play with these, could probably go even higher once $0 is fixed
  28. Mallardduck31
    That fixed it! Thanks guys
    I did not go in and change the $0 ever. How could this change on its own?
    The unit is set up as a router but do run with a laser add too.
    Chuck
  29. Peter Van Der Walt
    Maybe an accidental command sent while troubleshooting, or a misclick of the mouse into the settings tab :)
