OpenBuilds Control software & Lightburn
Discussion in 'General Talk' started by Jayhawk714, Nov 18, 2023.
  1. Jayhawk714
    Can OpenBuilds Control software be used in LightBurn without the Black Box? I have some files in OpenBuilds format but cannot get them to burn correctly in LightBurn.
    Thank you in Advance.
  2. Giarc
    Are the files saved as .svg or .dxf files? What "format" are you referring to when you say OpenBuilds format? By chance do you mean the gcode files created with the Openbuilds CAM software?
  3. Jayhawk714
    I need to open this file to do a test burn on a 20 watt laser I am having trouble with and it will not open correctly in LightBurn.
  4. Misterg
    Misterg Veteran
    It says it is a gcode file, so should open in Control.
    However, the message says that the file has been blocked (presumably by some anti-malware) - Have you tried unblocking the file?
  5. Giarc
    It also may not open properly if not made with Lightburn. I just tried importing about 10 different simple .nc files where the CAM was generated with different software, and Lightburn had issues with them all. Can you just get the original vector or image and generate the gcode for your laser in Lightburn?
    Also, if it is defaulting to open in the OpenBuilds Software, right click the file and choose "Open With" and select Lightburn. If you do not see Lightburn as a choice, select "choose another app" and find lightburn.
