Openbuilds Control won't open
Discussion in 'OpenBuilds Forum Help' started by ShaunC, Jun 21, 2022.
  1. ShaunC
    ShaunC New
    Newby query.
    I'm trying to install Openbuilds Control, which seems to have installed OK, but I cannot open the program. I have tried installing on two different PCs, same result. I get a message on initial install saying it has successfully installed and is running, but no GUI appears.
    Occasionally when I try to start the program I get an empty white window on the screen. When I try to open Openbuilds Control with Task Manager already running, an icon for Openbuilds Control appears, briefly, before closing again. Occasionally a message appears next to this icon with 'Suspended' appearing very briefly in the status column on Task Manager, before this message and the program icon disappears off the active program list. This indicates to me that the program starts to run and then quits. I have tried installing the last 3 previous releases, same results.
    I have checked Windows Updates and drivers, all are up to date. The two PCs I have tried are using different anti-virus software, so I do not think that is the cause.
    Any suggestions most gratefully accepted. Apologies if this is covered elsewhere on the Forum. I tried to search for existing answers but did not spot anything!
    Cheers, Shaun.
    redcnc109 likes this.
  2. Alex Chambers
    Have you tried clicking to open it a second time? OB Control opens first in the background - the gui opens with the second click.
  3. ShaunC
    ShaunC New
    Hi Alex,
    I have indeed tried this! No luck though.
    I have attached a screen grab of the pop-out message that says it has started successfully, as well as a shot from Task Manager which pops up very briefly before it vanishes off the active program list. Start Success msg.PNG Task Mgr.PNG
  4. Alex Chambers
    Sorry, you have exhausted my (very limited) expertise on this, but hopefully someone like @Peter Van Der Walt will be along soon with some truly expert advice.
    ShaunC likes this.
    Try reformatting that PC or try a different computer
  6. ShaunC
    ShaunC New
    Hi Peter,
    Thanks for the suggestions. I have now tried on another two PCs and these both worked.
  7. redcnc109
    redcnc109 New
  8. redcnc109
    redcnc109 New
    This is my first time using OpenBuilds and I am having similar trouble. I installed OpenBuilds Control v1.0.364, and it will not open on Windows 10. I do not have another computer to try installing the software and do not think that should be the fix.
    #8 redcnc109, Apr 6, 2023
  9. Giarc
    I have Windows 10 and it opens for me.
    On the lower right of your screen there is an "^" icon that opens up a menu and you can often find it there. Give that a shot and see.
  10. redcnc109
    redcnc109 New
    The icon does not show in the "^" menu, rather it appears on my desktop. The icon does not open the menu when I select it. The cursor becomes a spinning circle, indicating it is trying to open the application but then stops. The GUI does not open, and the task manager does not show OpenBuilds Control working in the background. I've reinstalled the software and rebooted the computer, and I have the same issue.
  11. Peter Van Der Walt
    Try a different computer (just to prove to yourself the application works fine - which it does - but the specific issue is that PC (conflicting application, broken OS, corrupt files, something specific)
  12. redcnc109
    redcnc109 New
    I do not have another computer to try the application on. I need to resolve the conflict on this computer.
  13. Peter Van Der Walt
    Then try a fresh reinstall of the Operating system. Or remove conflicting apps. Etc. Make sure it meets correct specs (win10/11 and wotkinUnfortunately we don't provide IT support but you could contact your local PC shop for example
    CONTROL is running successfully on a couple thousand users' machines :) the other PC test is just for yourself so you know where the issue is. People tend to ignore the "your PC has an issue" advice until shown "oh but it works fine on another PC"
  14. redcnc109
    redcnc109 New
    What apps on Windows 10 conflict with OpenBuilds Control that would prevent it from opening?
    #14 redcnc109, Apr 7, 2023
  15. Peter Van Der Walt
    Nothing we know of off hand, that's where IT Troubleshooting falls in.
  16. redcnc109
    redcnc109 New
    I identified the issue. When opening OpenBuilds Control, McAfee detects that harmful software is trying to hijack my apps. A solution is to turn off McAfee's "Real-Time Scanning," which undermines the purpose of anti-virus/anti-malicious software and creates a vulnerability.
  17. Peter Van Der Walt
  18. redcnc109
    redcnc109 New
    McAfee engineers spent the last three months troubleshooting, resolving the issue. The latest MaAfeed software is working and compatible with the OpenBuilds Control
  19. Peter Van Der Walt
    That is fantastic news! Thanks for submitting the reports!
  20. Ian Rusch
    Ian Rusch New
    Hi
    I have been having similar problems loading control on my HP Laptop running Win 10
    Have found that if I use the ^ from the task bar and Right click on the Openbuilds icon then select Open User Interface ( GUI ) it is more reliable
    See attached image
    Hope this may help others
