Openbuilds Software stopped mid job
Discussion in 'CNC Mills/Routers' started by KCollins, Jul 10, 2023.
  1. KCollins
    KCollins Well-Known
    Using the Openbuild Blackbox X32 with the Openbuilds Software. Just put my CNC together and am attempting to mill my spoilboard. I am trying to use the surfacing wizard in the software. I set my feeds and speeds with a DOC of 1mm. I started the job which was marked by the software to take 33 minutes... 9 minutes in it just stopped... No error no message no nothing. Just stopped. Seems odd... Any thoughts as to what might have caused it before I try running it again?
  2. Giarc
    MDF dust can generate a lot of static so it may be electromagnetic interference. If you "air cut" the same program, will it also stop?
  3. KCollins
    KCollins Well-Known
    Good idea Craig I'll try that tonight.
    The Serial Terminal tab's log would have had clues
  5. KCollins
    KCollins Well-Known
    Thanks Peter. I'll check those tonight if I have issues and see if that sheds any light on the topic.
