Experiencing strange behavior here where changes manually made in the GCODE editor are not reflected when I run the job. This occurs after right click resuming a job from a new position then making changes to the remaining code via the OpenbuildsCONTROL GCODE editor, then running the job, the changes made do not reflect in the behavior of the job that is run. For example, if I comment out lines of code the old uncommented code runs when the job is rerun after making the changes. EVEN if I select all the text and press the delete key so no code is in the editor, the RUN job icon still persists and I can run the job but I can't see the job in the editor and the job is old code? If I click the CLEAR button the RUN job button turns grey as it seems it should. Why is this behavior occurring?
