quenbe not works
Discussion in 'CNC Mills/Routers' started by Stefan Amlow, Oct 21, 2024.
  1. Stefan Amlow
    Hello, I have a new quenbe Pro 2500 x 1500 with Blackbox X32 and now wanted to operate it with the OpenBuilts software.
    I have everything connected. Unfortunately only the milling motor works.
    XYZ doesn't respond at all.
    Takes two things to move motors:
    1) Did you remember to load a machine profile (CONTROL > Grbl Settings > Select a machine from the list
    2) Proper 24V power (Our recommended meanwell, or 3rd party?) connected, correctly connected, and working
  3. Stefan Amlow
    I think so. I loaded the quenbe 1510 machine profile. And power supply is there too.
    Recheck :)
    No, use one of the profiles in the LIST :) - at least as a starting point - you can use the other vendors settings manually but don't overwrite key values like pin inversions, report masks etc ($4, 5, 6, 10 etc especially, keep the profiles we provide's values for these)
    Yeah but the right one, or one that could have damaged the BlackBox? See my question:
    At the end of the day, it's either not receiving power, or Grbl Settings are wrong.
