Scan Network Connect
Discussion in 'OpenBuilds Forum Help' started by Bobbolink, Jun 5, 2023.
  1. Bobbolink
    Bobbolink New
    When I do the scan it says found 0 devices. Looked up trouble shooter says not connected. Went to open builds documentation looked up open builds control refers to USB trouble shooting it said paged moved has to pictures of black boxes to choose from...takes you to another window for trying to solve USB problem and update. Down loaded the FTDI version for Windows 7 thru 11. Shut down the computer, brought it back up, went into open builds control window same darn problem. Control window will not open to allow me to continue working even on past projects. Your upgrades suck majorly!!! Finding the solution to the problems even worst runs you all over the place and you still don't have the problem fixed.
    Plug in a USB cable and connect (USB cable provided. Wifi is optional use case, USB is way easier and the recommended method shown in all our Machine build Videos)
    Then follow Section 7.1 and 7.3 of docs:blackbox-x32:start [OpenBuilds Documentation] first to get up to date, and secondly to add the X32 to your network.
    Don't forget to load a machine profile from the Grbl Settings tab too (you did watch the Wiring and Software video for the machine you have right? If not, please do)
