Vcarve GCODE file does not run
Discussion in 'CNC Mills/Routers' started by Speedgeek, Dec 27, 2023.
  1. Speedgeek
    Speedgeek New
    Just assembled a LEAD 1515 with blackbox X32. Ran the openbuilds test job successfully. Used Vcarve Pro to create a test job and saved to gcode. Loaded this gcode into the Openbuilds Control software. When I run the job nothing happens. The console shows
    [ GCODE Parser ] GCODE File (from gcode editor) sent to backend
    [12:33:28] [ T4 M6 ] ok
    then nothing. Gcode below, looking for help to understand what I need to do to get vcarve gcode to run?
    Here is the gcode:
    T4 M6
    G0 G17 G20 G90 G40 G49 G64 P0.001
    G0 Z0.8000
    G0 X0.0000 Y0.0000
    M3 M8 S18000
    G0X4.2449Y2.6780Z0.2000
    G1Z-0.1194F10.0
    G3X4.4685Y2.6644I0.2236J1.8299F30.0
    G3X4.6922Y2.6780I0.0000J1.8435
    G3X6.3120Y4.5079I-0.2236J1.8299
    G3X6.1833Y5.1847I-1.8435J0.0000
    G3X5.9512Y5.6034I-1.7148J-0.6768
    G3X4.4685Y6.3514I-1.4827J-1.0955
    G3X2.9994Y5.6215I0.0000J-1.8435
    G3X2.7621Y5.2055I1.4691J-1.1136
    G3X2.6250Y4.5079I1.7064J-0.6976
    G3X4.2449Y2.6780I1.8435J0.0000
    G1Z-0.2388F10.0
    G1Z-0.3583F10.0
    G1Z-0.4777F10.0
    G1Z-0.5971F10.0
    G1Z-0.7165F10.0
    G1Z-0.6772F30.0
    G1Z-0.7165F10.0
    G3X6.3120Y4.5079I-0.2236J1.8299F30.0
    G1Z-0.6772
    G1Z-0.7165F10.0
    G3X4.4685Y6.3514I-1.4827J-1.0955F30.0
    G1Z-0.6772
    G1Z-0.7165F10.0
    G3X2.6250Y4.5079I1.7064J-0.6976F30.0
    G0Z0.2000
    M3 M8 S18000
    G0X4.4685Y6.8238Z0.2000
    G1Z-0.0984F10.0
    G3X2.1526Y4.5079I0.0000J-2.3159F30.0
    G3X4.4685Y2.1919I2.3159J0.0000
    G3X6.7844Y4.5079I0.0000J2.3159
    G3X4.4685Y6.8238I-2.3159J0.0000
    G0Z0.2000
    G0Y6.6014
    G1Z-0.0984F10.0
    G2X6.5620Y4.5079I0.0000J-2.0935F30.0
    G2X4.4685Y2.4144I-2.0935J0.0000
    G2X2.3750Y4.5079I0.0000J2.0935
    G2X4.4685Y6.6014I2.0935J0.0000
    G0Z0.2000
    G0Y6.8238
    G1Z-0.1969F10.0
    G0Z0.2000
    G0Y6.6014
    G1Z-0.1969F10.0
    G0Z0.2000
    G0Z0.8000
    G0X0.0000Y0.0000
    M2
    Are you using the correct Post? docs:software:vectric [OpenBuilds Documentation]
    If that doesn't help:
    Any chance you also own an IoT relay?
    You have loaded the machine profile in CONTROL > Grbl Settings already? Did initial shakedown, jog tests, setup homing and all that?
    Does other Jobs run? Hello World for example? docs:blackbox-4x:hello-world [OpenBuilds Documentation]
    You are on CONTROL V1.0.370?
  3. Speedgeek
    Speedgeek New
    I do not own an IoT relay. I did load the default Lead 1515 grbl settings. The Hello World example does run. I am on control V1.0.370.
  4. Speedgeek
    Speedgeek New
    Okay I did not see that I need to select a Post processor. I will give that a try.
  5. Speedgeek
    Speedgeek New
    I was able to specify the Openbuilds post processor and my job ran. But, there was one toolpath that was supposed to cut a hole 18.2 mm deep but it cut 14mm, and a recess that was supposed to be 5mm deep but was 2.5mm. Any ideas on why?
    Thanks.
    • Acceleration / Max rates not tuned yet causing stall
    • Mechanical slip (check grubscrews on shaft couplers and sto collars, nutblocks tightened to plate correctly etc)
    • Mechanical stall (binding up somewhere in a z move)
    • Calibration
  7. Giarc
    Looking at the gcode, it looks like you zeroed on top of the piece. Did you use a touch plate?
    Also, what did you put in the boxes (Start Depth, etc):
