Version 1.0.377
Discussion in 'Control Software' started by Brian Pierson, Jun 28, 2024.
  1. Brian Pierson
    Just got the update to version 1.0.377 on our little mill here, and now the "Home all Axis" button is still greyed out and not working. Can you please shed some light onto this?
    #1 Brian Pierson, Jun 28, 2024
    Grbl Settings backup to see if it is replicatable? (CONTROL > GRBL SETTINGS TAB > Backup Settings button)
  3. Brian Pierson
    Interesting that the GRBL SETTINGS TAB wasn't even displayed. So, I shut down the control and restarted it from scratch and the tab AND the HOME ALL button both are present and working. Dunno' what happened, but we are back in business. :thumbsup:
  4. jeffmorris
    jeffmorris Journeyman
    I have the same problem. I have to shut down Control and started it up again.
    Alain JBT and Brian Pierson like this.
    Brian Pierson likes this.
  6. Alain JBT
    Alain JBT Well-Known
    As a precautionary measure in the future following an update (I always do it for me), you must always turn off your blackbox, reboot control and relaunch everything.
    :thumbsup:I have never had any problems following this procedure (even if it seems unnecessary).
    Another important thing, when your system is correct, don't forget to regularly make a backup of your settings and keep your own change log up to date (.TXT or other format) of the changes you make on the system.
    [Edit]
    For more security, with the free Software Notepad++ you can at any time compare different configuration files with the very useful comparison function, therefore you can detect all the changes made between the files in time.
    #6 Alain JBT, Jul 6, 2024
    Giarc and David the swarfer like this.
