VFD and Water Chiller control
Discussion in 'General Talk' started by BDrisc76, Jun 14, 2022.
  1. BDrisc76
    BDrisc76 New
    Is it possible to have a vfd spindle wired into the tool head plug for 0-10v and also use the relay port to power an iot relay? I’d like to plug my vfd and industrial water chiller into the iot so I can control them to turn on with my cam software.
    if possible, I’m assuming the jumper needs to be moved to M8 and then a simple M8 command with a pause for however long to fire up the vfd and chiller, then M3 with another pause to let the spindle spool up?
    #1 BDrisc76, Jun 14, 2022
  3. BDrisc76
    BDrisc76 New
    Thank you, that’s exactly what I’ll do. should have looked at the connections a bit more to see that the coolant port offered a 24v signal.
    I’m assuming I should remove the jumper that’s installed for the relay port?
