What did I do to get error:2
Discussion in 'OpenBuilds Forum Help' started by John Mitchell, Mar 23, 2024.
  1. John Mitchell
    Ive been cutting shapes with my diy plasma cutter until it sent me...
    error:2 Numeric value is not valid or missing an expected value [ PK ]
    When I send $ [HLP: $ $# $G $I $N $X=val $Nx=line $SLP $C $X $H ~ ! ? ctrl-x]
    What does it mean and how do I fix it?
    Reboot. Just EMi from the Plasma messing with the Serial queues :)
  3. John Mitchell
    Wish I could say rebooting fixed my problem but it didn't.
    Looks like corrupted OK.
    Does your code contain a PK?
  5. John Mitchell
    Yes it does contain [PK]
    Well then the error is spot on. Valid gcode only please...
  7. John Mitchell
    Sounds like the OpenBuilds community is going to throw me off the island.
    Hate to be the village idiot but how do I achieve this valid gcode?
    What did I do to cause the problem?
    The more info you include the more we are able (and willing) to assist.
    Where's the gcode from that contains these non gcode commands. What CAM are you using. Are you sure it's Grbl compatible? etc
    Include full logs (not truncated) and samples of any gcode you are needing help with. With how little you give us, best we can offer are a couple guesses
  9. John Mitchell
    Fusion 360 CAD and OpenBuilds as the CAM. That combo had worked well for two months with over 50 drawings converted to metal parts. 3 days ago I opened my computer to burn a part and the [PK] error code would not allow it. That means everything was compatible.
  10. Alex Chambers
    Can't help much with where that errant g-code came from, neither programme should produce that, but I do recommend learning Fusion cam - Openbuilds cam is deliberately designed as a simple "get you started" option.
    Use this post processor with Fusion cam -
    docs:software:fusion360 [OpenBuilds Documentation]
    #10 Alex Chambers, Mar 24, 2024
  11. Peter Van Der Walt
    We're still waiting
