Why would this happen with XYZ probe
Discussion in 'CNC Mills/Routers' started by grahamdvd, May 5, 2024.
  1. grahamdvd
    grahamdvd New
    I used to use the Openbuilds Interface on my cnc machine. I had lots of trouble with it crashing etc and touch buttons doing there own thing. I loved the interface but just had enough in the end so started just using my laptop.
    It was fine, not as convenient as the Interface but at least it worked.
    I used my laptop on my cnc tonight and had to connect the charger since it had a low battery.
    When I used the Openbuilds XYZ probe it registered and lit up green as soon as i connected the magnet to the spindle, even though it was not touching the bit?
    After unplugging things etc it seems its when I connect the laptop charger to my laptop which my Black box is connected through a USB?
    Why is that?
    AC EARTH to DC GND short somewhere.
    Two prong plug on mains side? Try turning it around (live/neutral reversal) or it might be a leak inside the charger (replace)
  3. grahamdvd
    grahamdvd New
    Hi I'm in uk so it's 3 pronged plug and no way to change L/N round.
    It's a moulded plug into mains AC and the same into charger so factory done. I will try another charger
