Xtreme V Wheel Spacing
Discussion in 'CNC Mills/Routers' started by BeeAMaker, Feb 7, 2025.
  1. BeeAMaker
    BeeAMaker Well-Known
    I'm building a specific use machine and intend to use the 20x80 rail for the X and the 40x80 C-Beam for the Y.
    The previous machine I built for this specific use, I used the OX build plates, but this time I need to make my own plates.
    I downloaded the DXF for the OX gantry plates and I see the V wheel spacing is 99.7995mm while the spacing on the C-Beam Gantry plate is 100.6mm
    When designing my own plates, which spacing should I go by?
    With the OX and other earlier generation plates folks often overtightened eccentrics, flattening/cracking wheels. So we moved it outward just a little to stop people (who skip the step and just crank the eccentrics all the way) from damaging their Wheels. So either is fine, but personally I like it a little closer, i know how to set eccentrics correctly :)
    BeeAMaker and David the swarfer like this.
  3. BeeAMaker
