Xyz probe can the datum be changed?
Discussion in 'CNC Mills/Routers' started by grahamdvd, May 5, 2024.
  1. grahamdvd
    grahamdvd New
    I've always used bottom right corner for my datum point. I tried the zooen builds xyz probe and by default its the bottom left. Is there a way to change it permantly?
    I don't really want to measure each piece of work and set an offset each time just a simple pick a datum position and thats it.
  2. sharmstr
    Click on Advanced, then select the one you want
  3. grahamdvd
    grahamdvd New
    Thanks yes I tried that, but then it asks for stock measurements of the material so it can put an offset? Do you have to do that everytime?
    Yes
    Or just start to CAM in the far more standard and convenient way of bottom left corner origin :)
  5. grahamdvd
    grahamdvd New
    Thanks I will start using the bottom left from now and treat it as the norm
