I took the basic 1000mm linear actuator
Attached linear rails to the sides for stability
Use my old 3018 CNC to mill side plates from 1/4" aluminum plate
Painted finished plates
Added 2080 v-slot to support 3rd 1000mm actuator for x axis
Added linear rails for x axis and mounted 250mm actuator for z-axis
Milled and fully installed z axis supports. First test cut!
Finished spoiler with tracks installed
Wired up Blackbox controller and made custom z-probe
Some closer pix of z axis
1010 with linear rails
Build in 'Cartesian Style CNC' published by Bferster, Aug 24, 2022.
Has a 700 by 700 cutting area and is very stable
 samir alsurihi, DaddyMac and Richard148 like this.
			Build Author Bferster, Find all builds by Bferster
					Build Details- Build License:
 Reason for this BuildI had a Genmitsu 3018, nut it was too small. I liked the idea I could build my ownInspired by1010 stock cnc
					Parts listQty Part Name Part Link Comments 3 1000mm linear actuator w/ stepper Link 1 250mm linear actuator w/ stepper Link 1 Spindle router w/ LED Link 4 2080 V slot 250mm Link 2 1000mm drag chain Link 4 2040 vslot 1000mm Link 1 Power supply bundle Link 1 Blackbox controller Link 1 Dust boot https://www.amazon.com/dp/B0B1BV9F4X?ref=ppx_yo2ov_dt_b_p... Link 1 t Track https://www.amazon.com/dp/B09DCBLV8P?ref=ppx_yo2ov_dt_b_p... Link 1 Corners https://www.amazon.com/dp/B08YMR984W?ref=ppx_yo2ov_dt_b_p... Link 2 Z axis linear rails https://www.amazon.com/dp/B08HWD38YL?ref=ppx_yo2ov_dt_b_p... Link 2 X/Y axis linear rails https://www.amazon.com/dp/B08H8CDFT9?ref=ppx_yo2ov_dt_b_p... Link 2 Corners https://www.amazon.com/dp/B0855CRFWQ?psc=1&ref=pp... Link 2 L slot corners https://www.amazon.com/dp/B07JBX2NDL?ref=ppx_yo2ov_dt_b_p... Link
