In this construction I tried to have as little as possible hand made parts. I wanted to have an open frame that I can place over bigger wood plates to engrave.
V-Slot™ Mini V Linear Actuator Bundles are perfect for that. You can just screw the main axes together without needing any additional mounting brackets.
For the electronics, I decided to use an Arduino Uno with Grbl 1.1f and a Prontoneer CNC-Shield.
On software side I will use LaserWeb4.
1x1 Meter Laser Engraver
Build in 'Laser Cutter Builds' published by COMsulting, May 1, 2017.
Building of a big open frame laser engraver.
Anthony Bolgar and MaryD like this. -
Build Author COMsulting, Find all builds by COMsulting
Because it's fun
Qty Part Name Part Link Comments 2 V-Slot™ Mini V Linear Actuator Bundle http://openbuildspartstore.com/v-slot-mini-v-linear-actua... Link 20x40mm, 1000mm long 1 V-Slot™ Mini V Linear Actuator Bundle http://openbuildspartstore.com/v-slot-mini-v-linear-actua... Link 20x20mm, 1000mm long
