Frame is from 20x20 and 20x40 black anodized aluminium v-slots. Connected mainly with custom cuted alu plates.
Building space is 300x300x300 mm. Powered by MKS SBASE 1.2 with 3,2ā³ MKS-TFT display. Heated bed is 220v and 600w, power supply is 12v 30A 360W. Raspberry PI 2 model B 1 GB for to connect to the Internet. Dual MK8 extruder configuration.
3d nika
Build in 'Cartesian Style Bots' published by griso, Jul 3, 2016.
Over 840 parts. Of whom around 450 are screws and nuts, more than 100 parts are printed on a 3D printer, the frame consists of about 60 components. There is nearly 40 electrical components connected with tens of meters of wires, most of them sleeved.
More photos on: https://goo.gl/photos/DJRAVBz2fcQxdYXM7
Build Author griso, Find all builds by griso
I wanted something stronger, bigger and more durable than what is commonly sold and not too expensive. Apply in future as a CNC milling machine too. -
Qty Part Name Part Link Comments 5 V-SLOT 2040 - Black Anodized Link 3 V-SLOT 2020 - Black Anodized Link 5 Nema 17 Stepper Motor 59Ncm(84oz.in) Bipolar 4-lea Link 1 24V-380V 40A 250V SSR-40 DA Solid State Relay Modu Link 1 silicone heating pad heater 220V 600W 300 * 300 mm Link 16 custom cut and elox aluminium plates Link 1 MKS SBASE V1.2 opensource 32's Motherboard compati Link 1 MKS TFT32 touch screen smart controller 3.2inch Link 2 MK8 Extruder Print Head J-head Hotend Throat E3D Link 1 RASPBERRY PI 2 MODEL B 1GB Link 1 High tolerance CNC mini v wheel kits for v-slot Link 6 L-Shape Interior Corner Connector Joint Brac Link 2 Rod Plate for Nema17 Link 1 Aluminum Alloy Timing Drive Pulley for DIY 3D Prin Link 2 Stepper Motor Flexible Coupling Coupler /Shaft Cou Link 1 Aluminum GT2 16T 6mm Bore Pulley and 2M Timing Link 2 50 x 50 x 15mm Electronic 3D Printer 12V DC 50mm B Link 5 Microswitch AC 250V 15A HV-156-1C25 SPDT Rol Link 1 LJ12A3-4-Z/BX Inductive Proximity Sensor Detection Link 1 Super Cool White 5M Waterproof 300LEDs 3528 Flexib Link 1 60pcs/lot 2020 aluminum profiles T Slot nuts m3, m Link 1 1 kg pla, gold 1,75mm Link 1 DC Converter Module 12V To 5V 3A 15W with Micro US Link 2 towline cable 10*10mm-1000mm Link 1 10pcs Spring For 3D Printer Extruder Heated Bed Link 50 Zinc Plated Tee nuts for building machine M5 bore Link 1 Zinc Plated double Tee nuts M5 bore 30pcs Link 1 4A CNC Single Axis 4A TB6600 2/4 Phase Hybrid Step Link
