To see here, some detail photos that you can download.
Here to see, some example from PDF drawings, that you can download.
The unwinding drawings are also included.
I create this 3D Printer with Inventor 2013. You can also download the Inventor files, to make changes and create your own.
Download Inventor 2013 file: http://www.thingiverse.com/thing:190995
Youtube Video:
In the foulder "Details" (to download) you find some information about:
- Enery chain
- Microswitch
- Emergency stop pushbutton
- Contoller board + Fan
- Shielded motor cable
- Power supply
- Extruder
I hope this are enough information to create your own Printer!
Have fun to buildt!!!
3D Printer - Big Size
Build in '3D PRINTER BUILDS' published by AK-Creation, Feb 14, 2014.
I creat a open source 3D Printer to print big things. Print size: 400x500x300 mm. You can download the Drawing in PDF and in Inventor 2013 format. The unwinding drawings are also included. I take some detail photos for a better understanding.
Galim, nin1356, Hades Corps and 7 others like this. -
Build Author AK-Creation, Find all builds by AK-Creation
I want to build a vertical roof wind turbine with a slowly gearless rotating power generator. The current generator to a diameter is 300 - 400 mm.
The normal 3D printers have only a print area of 200 x 200, so I must build me a bigger one. I planned to print the complete roof wind turbine. -
