Using 2 maker-rails, some 1/2" aluminum angle and 3D printed parts. We built this leveler for a 3D printer and it seems to work well because while you level to the [print] bed to the hot end. The bed it self can still be slightly off kilter with regards to gravity and this can affect the print. In addition it also seems to dampen the issue of vibration during rapid infills and this has reduced the "catching" of the second extruder on the dual filament printer.
Pads: 2 Inch Maker-Rail Pad for 3/4 Inch #8 Bolt and Nut by CallJoe
Hex Feet (for 1/2 inch hex head bolt): 1.5 Inch Feet for 0.25 Inch Bolt Heads by CallJoe
Round Feet (for 1/2 inch round head bolts): 1.5 Inch Feet for 0.25 Inch Round Bolt Heads by CallJoe
For more information this and other builds, please visit us at www.DIY3DTech.com also check our YouTube video on this and Channel at
3D Printer Leveler Made with Maker Rail
Build in 'Everything Else' published by DIY3DTech.com, Oct 29, 2015.
Leveling Platform / Stand 3D Printers
When working with tools always remember safety first!
Build Author DIY3DTech.com, Find all builds by DIY3DTech.com
The object for building this was to improve the the prints from my 3D Printer and seems to have done the job on top of looking pretty cool too! -
Qty Part Name Part Link Comments 2 500mm long 10mm Maker-Rail Link 2 18 Inch Length Aluminum Angle Link I used 18Inch for printer however your might be different 4 1/2 Bolt Link You can choose hex or round just match to the STL 8 1/2 Inch nuts, washers (2x for top and bottom) Link 4 1/2 Inch Lock Washers Link -
