Thanks for stopping by! Check out the discussion tab for a lot more pictures and information.
7050 Sphinx
Build in 'Cartesian Style CNC' published by Michael.M, May 25, 2018.
-Thanks to Kyo Shinohara for his awesome design and his help
-Thanks to the OpenBuilds team for their top notch customer
service
-Thanks to Chris Laidlaw (Blue Ox Solutions) for the amazing
plates
AntiShin, Abdulbasyr Gurbanov, Rhett E and 49 others like this. -
Build Author Michael.M, Find all builds by Michael.M
I've been infected by the Tinker BugInspired by
Kyo Sphinx -
Qty Part Name Part Link Comments 1 Deluxe 2" Taller Kyo Sphinx CNC 4W-X-9 Plate Set https://www.ebay.com/itm/Deluxe-2-Taller-Kyo-Sphinx-CNC-4... Link Contact Chris Laidlaw directly. Email: [email protected] 4 4 × NEMA 23 Stepper Motor - High Torque Series http://openbuildspartstore.com/nema-23-stepper-motor-high... Link 1 24V /14.6A Meanwell Power Supply http://openbuildspartstore.com/24v-14-6a-meanwell-power-s... Link 4 DQ542MA Stepper Motor Driver http://openbuildspartstore.com/dq542ma-stepper-motor-driver/ Link 1 Phoenix USB CNC Controller with PWM Output https://www.tindie.com/products/PhoenixCNC/phoenix-usb-cn... Link 1 Router/Spindle Mount (Optional) http://openbuildspartstore.com/router-spindle-mount/ Link This is optional and not needed if you purchase the Blue Ox Mount 1 Blue Ox Router/Spindle Mount (Same as mine) https://www.ebay.com/itm/Designed-to-Order-Router-Spindle... Link Contact Chris Laidlaw 2 3GT Timing Pulley 20 Tooth 9mm Belt 8mm Clamp Bore http://openbuildspartstore.com/3gt-gt2-3m-timing-pulley-2... Link This pulley clamps onto the end of your leadscrew 2 3GT Timing Pulley - 20 Tooth - .250" Bore http://openbuildspartstore.com/3gt-gt2-3m-timing-pulley-2... Link This pulley clamps onto your stepper motor shaft 2 3GT 9mm Timing Belt - Closed Loop http://openbuildspartstore.com/3gt-gt2-3m-9mm-timing-belt... Link 2 8mm Metric Acme Lead Screw 1000mm http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link These two Acme leadscrews will be for your Y axis 1 8mm Metric Acme Lead Screw 500mm http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link This single Acme leadscrew will be for your X axis 1 8mm Metric Acme Lead Screw 250mm http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link This single Acme leadscrew will be for your Z axis 7 Anti-Backlash Nut Block http://openbuildspartstore.com/anti-backlash-nut-block-fo... Link This design calls for double nut blocks on your Y and X axis. 2 C-Beam® End Mount http://openbuildspartstore.com/c-beam-end-mount/ Link 2 Reduction / Stand Off Plate http://openbuildspartstore.com/reduction-stand-off-plate/ Link 2 C-Beam® Linear Rail 1500mm http://openbuildspartstore.com/c-beam-linear-rail/ Link The total length of C-Beam needed will depend on your desired machine size 3 V-Slot® 20x60 Linear Rail 150mm http://openbuildspartstore.com/v-slot-20x60-linear-rail/ Link The total length of V-Slot needed will depend on your desired machine size 24 Xtreme Mini V Wheel™ Kit http://openbuildspartstore.com/xtreme-mini-v-wheel-kit/ Link 28 Xtreme Solid V Wheel™ Kit http://openbuildspartstore.com/xtreme-solid-v-wheel-kit/ Link The Blue Ox plate set calls for additional wheels 6 Flanged Bearing 688ZZ 8x16x5 http://openbuildspartstore.com/flanged-bearing-688zz-8x16x5/ Link 2 Ball Bearing 688Z 8x16x5 http://openbuildspartstore.com/ball-bearing-688z-8x16x5/ Link 9 Shim - 12 x 8 x 1mm http://openbuildspartstore.com/shim-12-x-8-x-1mm/ Link 8 Lock Collar 8mm I.D. http://openbuildspartstore.com/lock-collar/ Link These are installed at each end of your leadscrews 2 1/4" x 8mm Flexible Coupling http://openbuildspartstore.com/1-4-x-8mm-flexible-coupling/ Link These connect your stepper motor shaft to your leadscrews 30 Eccentric Spacer http://openbuildspartstore.com/eccentric-spacer/ Link These allow fine adjustment of your Xtreme V-Wheels 6 Precision Shim - 10x5x1mm http://openbuildspartstore.com/precision-shim-10x5x1mm/ Link 12 End Cap (for the exposed ends of your V-Slot) http://openbuildspartstore.com/end-cap/ Link 16 Black Angle Corner Connector http://openbuildspartstore.com/black-angle-corner-connector/ Link 100 Tee Nuts (25 Pack) x 4 http://openbuildspartstore.com/tee-nuts-25-pack/ Link You don't need all 100 of these for the build but you'll want more down the road 60 Nylon Insert Hex Locknut - M5 http://openbuildspartstore.com/nylon-insert-hex-locknut-m5/ Link You'll want extras of these as well 1 Low Profile Screws M5 60mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 1 Low Profile Screws M5 50mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 1 Low Profile Screws M5 30mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 2 Low Profile Screws M5 25mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 1 Low Profile Screws M5 20mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 2 Low Profile Screws M5 15mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 2 Low Profile Screws M5 10mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 8 Aluminum Spacers 40mm http://openbuildspartstore.com/aluminum-spacers/ Link 14 Aluminum Spacers 9mm http://openbuildspartstore.com/aluminum-spacers/ Link 26 Aluminum Spacers 6mm http://openbuildspartstore.com/aluminum-spacers/ Link 14 Aluminum Spacers 3mm http://openbuildspartstore.com/aluminum-spacers/ Link 1 .8Kw Spindle & VFD Huanyang https://www.amazon.com/Spindle-Cooling-4Bearings-24000rpm... Link This is the exact spindle package I bought. 1 Awesome Coolant Mister / Air Blast https://www.amazon.com/gp/product/B071DXGGP4/ref=oh_aui_d... Link I've tried a couple different nozzles now and for the price, this thing is amazing! 1 California Air Tools Mini Compressor *Quiet* https://www.amazon.com/gp/product/B01LYHYHEA/ref=oh_aui_d... Link This thing is very quiet. A must have for the apartment CNC! 1 PC Water Pump / Res Combo https://www.amazon.com/gp/product/B01MF6WAY9/ref=oh_aui_d... Link This pump & res combo is very compact, the size of a CD drive 1 120mm Radiator https://www.amazon.com/gp/product/B01D82BG1S/ref=oh_aui_d... Link It works, no leaks! 1 Kyocera Endmills 1/8" https://www.ebay.com/itm/10-1-8-1250-2-FLUTE-CARBIDE-ENDM... Link I have made multiple purchases from this seller. You won't find better bits for the price. 5 Creltek Limit Sensor 343RT https://www.tindie.com/products/kevpatt/creltek-limit-sen... Link I bought 6 of these but will only use 5 because I don't use a Z MIN electronic limit 1 Creltek RJ-11 Sensor Breakout https://www.tindie.com/products/kevpatt/creltek-rj-11-sen... Link 2 15mmx40mm Black Nylon Towline Cable Drag Chain https://www.amazon.com/gp/product/B072N11TCZ/ref=oh_aui_d... Link 50 Low Profile Screws M5 8mm http://openbuildspartstore.com/low-profile-screws-m5-10-p... Link I'm so sorry I forgot this initially!! The most common bolt on the machine...... -
