This machine was inspired by openbuilds desings, with a short budget and less posibilita of find some materiales here in argentina, for example the c-beam profile.
Total size: 710mm (long), 800mm (width) and 370mm (height).
Work area: 520mm (long), 520mm (width) and 60mm (height).
The CNC has a base made with 2020 profile under a 18mm MDF table and guides made with 2040 v-slot perfiles (there aré two joined 2040 perfiles in the x axis)
The first versión will have plastic (APM) plates and the idea is that the next one will have aluminum plates.
I used NEMA 17 motor to move X and Y axis with medium torque, 6mm timing belts and 20 tooth pulleys. Also i used a NEMA 17 motor to move Z axis and 8m lead screw
A very affordable CNC routing
Build in 'Cartesian Style CNC' published by javierburger, Jun 1, 2020.
In progress CNC, (just design for the momment), I want to get some feedback about the design and the possible flexion of the aluminum profiles chosen
James Lockhart, Marcelo Der, dirtybglass and 2 others like this. -
Build Author javierburger, Find all builds by javierburger
I have been reading for 3 years about CNC milling, laser, plasma, etc... And I became fanatic of diy CNC systems using arduino+grbl electronics
![[IMG]](proxy.php?image=https%3A%2F%2Fopenbuilds.com%2Fdata%2Fattachments%2F46%2F46048-150d3a3af415136cdd8486c38ba0f7ba.jpg&hash=648bb519b6f2f5047a3c80ff11e5841b)
![[IMG]](proxy.php?image=https%3A%2F%2Fopenbuilds.com%2Fdata%2Fattachments%2F46%2F46049-c489fe2b97e057c501361670504177f2.jpg&hash=21a07a09e1b46990eb0fce374ab40a5c)
![[IMG]](proxy.php?image=https%3A%2F%2Fopenbuilds.com%2Fdata%2Fattachments%2F46%2F46050-d763a065a6c0d4c1add9661cb9e3689e.jpg&hash=522ccdb88539849c914ab602f3b2ce5b)
