This is the Gigantic ACRO system from openbuilds store.The machine was mounted by the instructions on the video. I made the table and other details necessary to put that monster to work. Using 15 watt chinese laser. The CNC Xpro V3 driver is very easy to use and with good documentation and came with GRBL V 1.1f. In the end of the post you can see the parameters i use to make all run smooth...hope it helps, the grbl configuration is allways the most confusing part .
For a machine that size it is very dificult to make it work without end stops, so i used 2 in x
and y and made a "system" to manage the cables
Here is the GRBL CONF:
Machine connected
Firmware grbl 1.1f detected
$0=10
$1=255
$2=0
$3=6
$4=1
$5=0
$6=0
$10=1
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=114.290
$101=114.290
$102=114.290
$110=10000.000
$111=10000.000
$112=10000.000
$120=2000.000
$121=2000.000
$122=2000.000
$130=1300.000
$131=1300.000
$132=68.000
ACRO 150 X 150 CM
Build in 'Laser Cutter Builds' published by CLAUDIO MIKLOS, Feb 24, 2018.
Openbuilds ACRO
Jason Grace, MartĂn Be, Rene76 and 7 others like this. -
Build Author CLAUDIO MIKLOS, Find all builds by CLAUDIO MIKLOS
Need a monster laser !
