12/1/20
So I was looking in incorporating ball screws on my machine.Either way with the stock bearing blocks funky size and trying to mount to the c beam ext I would have to create custom plates anyways. I bought a 250mm 1204 ball screw off Ebay to tinker with. So I sketch'd up a some plates to accommodate a better set of bearings then the stock BF n BK bearing blocks have. My goal was to create a carrier that would be low profile hold new bearings with linear rails and hold stepper motor like Openbuilds way. I cut up some HDPE plastic I had bought for another project, its a static prototype just for build purposes. I want to utilize 3/8" thick Alum flat bar and 20x20 Alum Ext. I have on there T slot but the V slot will work too. Using the T/V Slot ext to hold the linear rails. I went with 20x20 ext cause I had to raise the linear rail guides off the base plate get close to the ball screw block and machining out a set rails for rails was looking to be painful. What I found out cause I jumped a little before I looked was that a 250mm ball screw only has a effected travel of 186mm along the screw. I should have looked at the dimensions first. So I might have to adjust the linear rails a little with a metal cut off wheel. The Uprights holding the bearing are secured thru the back of the base plate.Plus bolt wholes that will secure the bearing plate to the 20x20 ext. There will be small spacer between the top bearing and plate to maintain squareness.I believe also I might have to place a spacer on ball screw block or the linear bearings or i decided to mill reliefs on the Z axis plate spindle plate can't remember what I decided. I will post files after I have a finalize the part. Pics are a little dark cause of the plastic.
12/10/20
So I liked the way the end plates worked in plastic so I cut the pieces out of 3/8ths alum Flat bar. Waiting on more aluminum to cut the base. Places 5.5mm spacer between upper plates bolts go thru to alu ext and will also be bolted down to base plate. Also making Motor stand off need to 3d print this.
Bearing pockets are facing in held tight flush against the screw.
2/6/21
So had total redesign gonna post pic and work on posting files a little later. I was trying to make it as low as possible.
The goal was to get the ball screw block as low to the plate. So that ended up have to be mill out a slot so the Anti back lash ball screw block could sit even with the hgh 20 blocks. I have a temp 3d printed plate on there to line the ball screw in the middle.
Also designed a 3d printed motor mount. When used in a compression type situation 3d printed parts good. I have also made the motor plate tied to the inner bearing plate.
You will have to excuse some of the milling flaws on the parts. I had alot of problems with stepper couplers not holding on tight and breaking and some that was flat out to big. Wish I had bought OB
couplers along time ago. I have them now. Seems to be holding good after the correct steeper couplers. Here's update pic of the rig went from wheels to Linear hgn12 rails. Had redesign for cutting aluminum.
Next step is building the double c beam x axis I have not decided how large I was going to go but I'm thinking around 800mm to 1000mm foot print on the X and Y Axis. This machine is running pretty decent. Just love building. Sooner or later got to back to my flight simulator build.
Ball Screw Carrier.
Build in 'Cartesian Style CNC' published by Corey Corbin, Feb 7, 2021.
Create a ball screw carrier with out BF BK bearing blocks.
I was inspired by Netechsys's build to start a ball screw router build.
Antonio777, Tomas Pontes, Lord Chalfont and 6 others like this. -
Build Author Corey Corbin, Find all builds by Corey Corbin
Just to improve my cnc building and running my machine skills.Inspired by
Qty Part Name Part Link Comments 1 Nema 23 425 inoz stepper https://www.amazon.com/gp/product/B00PNEPW4C/ref=ppx_yo_d... Link Its Nema 23 bolt spec so any Nema 23 will work 1 uxcell 8mmx10mm Clamp Tight Motor Shaft 2 Diaphrag https://www.amazon.com/gp/product/B078VR9V7J/ref=ppx_yo_d... Link 2 XiKe 10 Pcs 6200-2RS Double Rubber Seal Bearings https://www.amazon.com/gp/product/B0716NGDBR/ref=ppx_yo_d... Link Bearings are negotiable. Just what I used. 1 XiKe 10 Pcs 608-2RS Double Rubber Seal Bearings https://www.amazon.com/gp/product/B07JJ526NX/ref=ppx_yo_d... Link Bearings are negotiable. Just what I used. 1 1204 Ball Screw https://www.ebay.com/itm/CNC-Ball-Screw-12mm-SFU1204-w-Ba... Link for refernce only that ball screw its designed around. Files can be change and adapted. 0 Link -
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2F474t4L6%2FIMG-1773.jpg&hash=1717b06d87a025f65272eaee28986e2e)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FtDQP1PZ%2FIMG-1772.jpg&hash=12ecfedb1be0aea22bde445cb5d6b758)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FwJP58G0%2FIMG-1771.jpg&hash=abcca5be2af9b455c6e6d51ce82e5b3e)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FhfM1742%2FIMG-1770.jpg&hash=4a0b9dd2cdda484b77d6a5c8b443a0ae)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FfrTt2PY%2FIMG-1791.jpg&hash=8e7002b354af598ceeccb70be188faf7)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FGkYRWsz%2FIMG-1792.jpg&hash=2d54e065ca9b9f09928f8b7e7fc83c42)
![[IMG]](proxy.php?image=https%3A%2F%2Fi.ibb.co%2FWG57SC5%2FIMG-1793.jpg&hash=99cda23bae3497b74b8439999e8ffb67)
