This is my first CNC machine build that I like to use for PCB milling.
I decided to use the C-Beam Machine Plate Maker as starting point. I build the machine using the build video during the x-mas holidays. The build is not finished yet but everything is operational. The first thing I like to add is a panic button.
In the future I like to buy a DeWALT router for more demanding work. For now I think the Dremel 4000 wil work for PCB milling. I 3D printed an insert for the standard router mount to fit the Dremel. I designed and 3D printed a housing for the xPro and the end caps currently printed in blue. I added the STL files if you need them.
I use OpenCNCPilot to probe the PCB and send the gerber file.
C-Beam™ Machine for PCB milling
Build in 'X/Y Table Style CNC Mill' published by Carl van Heezik, Feb 3, 2018.
C-Beam Machine for PCB milling
Mark Carew, antonio mata gonzalez, RobConway and 1 other person like this. -
Build Author Carl van Heezik, Find all builds by Carl van Heezik
PCB milling and general purpose CNC machineInspired by
C-Beam™ Machine - Plate Maker -
