C-Beam® Tension XL Linear Actuator Bundle
In this Build, we will put together a linear actuator that incorporates a tensioning system
so we can achieve longer lengths while still including a lead screw transmission.
The result is strength and accuracy without lead screw “whipping” and we are really happy with the results.
The gantry cart is capable of being mounted 90 degrees to each other creating
either an X/Y system or even an X/Z system for a CNC machine.
We are excited to see how this actuator will be used/modified and please remember to
share your ideas here on OpenBuilds!
Tension System Details:
Tension added through Thrust Bearing and Tension Nut. Dual Nut Blocks added for stability of transmission. Modular design is available in multiple lengths and colors XL Gantry Plate used for strength and rigidity ![]()
Travel Details:
Travel for the 1500mm version is 1365mm.Step by step build along video:
Tension Nut is easily adjusted to add tension to your lead screw for longer lengths!
Thrust Bearing utilized on both sides of the actuator to maintain strength and stability!
Dual Nut Blocks added to maintain strength and rigidity for linear motion!
Gallery:
Build in 'ACTUATOR' published by OpenBuilds, Sep 30, 2020.
JayMcD likes this. -
Solution for longer powerful and extremely accurate actuators using lead screws.Inspired by
Inspired by the awesome tension mod by @David Tingle -
