I'm calling this the C-Beam 2XL since I doubled the cut area.
Instead of the 500mm C-Beams for the Y axis I went with 1000mm C-beams and a larger MDF base board.
Some details
- Mach3 control software
- Mach3 breakout board
- TB6600 motor drivers
- Dewalt Router
I built this mostly to cut aluminum plates and after the first few cuts I can say I'm extremely impressed with the cut quality and the accuracy of the parts. (I regularly use a Waterjet so I have a comparison and I will be now using this instead for most parts)
Also of note I'm cutting aluminum at 30 ipm and have ran it up to 45 ipm with a cut depth of .03.
Update: I've now replaced the MDF platform with a 3/8" aluminum plate. Seen in IMG_6857.jpg
C-Beam "2" XLarge CNC Router
Build in 'X/Y Table Style CNC Mill' published by mcbuilder22, Apr 28, 2017.
C-Beam 2XL CNC Router
Tomas Pontes, Donald F Lytle, Boathpy and 9 others like this. -
Build Author mcbuilder22, Find all builds by mcbuilder22
To cut aluminum parts.Inspired by
C-Beam XL Machine -
