The fluid comes from two pressure tanks with an internal mixing system to keep the fluid from separating over time. With air pressure, the fluid is forwarded to the mixing valve. The mixing valve has the option to calibrate the flow of each fluid into the static mixing tip. The mixing valve also has a suck back feature to prevent the fluid to drip and mix unevenly inside the static mixer.
All pressure tanks, valves, and mixers come from Vmatic.
The controller and motor driver and motors from PoLabs running Mach4 on a computer.
Power supplies from MeanWell and Lambda.
Relays from Omron.
Dual row terminals from UKK.
Mechanical parts from Openbuilds.
Control cabinet and all parts not extruded on the machine is self-made by aluminum sheets.
CNC Coating Machine
Build in 'Everything Else' published by Vegard Humlen, Dec 1, 2018.
The purpose of this machine is to mix two parts of conformal coating with different viscosity in exactly 1:1 ratio and distribute the fluid on to PCB to seal and make it waterproof.
GrayUK, Mark Carew, sharmstr and 1 other person like this. -
Build Author Vegard Humlen, Find all builds by Vegard Humlen
The machine was built to automate the process and have a more consistent result.
