I am currently Working on a CNC Build for Cutting Foam for Hot Wire Cutting.
I have already built the 24V Power Supply to heat up the wire and am using it on custom build Foam Bow Cutter.
CNC Hot Wire Cutter 4 Axis for Cutting Foam Wings
Build in 'Everything Else' published by Rusticalmond, Sep 20, 2015.
My build is to allow me to cut foam wings using CNC Hot Wire Cutter.
My Power Supply Ready to go
My smaller Bow for hobby cutting model terrain for 3d War Gamming.
Build Author Rusticalmond, Find all builds by Rusticalmond
To Cut Foam Wings not having to use templates. -
Qty Part Name Part Link Comments 1 4 Axis Nema 23 Electronics Kit plus power supply http://www.ebay.com/itm/271846143198?_trksid=p2055119.m14... Link Kit Ordered 8/28/2015 1 USB To DB25 Parallel Port Printer Adapter Cable http://www.ebay.com/itm/310879639405?_trksid=p2057872.m27... Link Did not work, did not allow me to create LPT Port 1 24248SCNK http://www.nemaenclosures.com/ Link Type 1 Enclosure with Screw cover 24x24x8 Purchased at Crafwford Electrical 75.00 4 5pcs Aviation Plug Male Female Wire Panel Metal Co http://www.amazon.com/Aviation-Female-Panel-Connector-Cha... Link 4 Pin Aviation plugs for quick Disconects on motor wiring 1 RS-25-5 http://www.mouser.com/ProductDetail/Mean-Well/RS-25-5/?qs... Link Mean Well 5V Power Supply 1 Rosewill RC-302 - PCI Card - Single Parallel Card http://www.newegg.com/Product/Product.aspx?Item=N82E16815... Link Gives my computer a Parallel LPT Port to interface with Mac 3 0 Link -
