I already have a plasma cutting table made with openbuilds products , but when i saw the metalguru's idea , i said "whoaww" , this build will be perfect for me .
A compact plasma cutting table , easy to carry . neither to big nor to small
I will describe here the advance of this assembly
First : The idea ( picture from Metaguru )
And now , let's go working :
Plasma generator will be an Esab Cutmaster A40 or A60 .
The A-serie from Esab is perfect for this kind of use .
CNC control board is already build in , Torch will be a mechanical one (SL 180 from esab )
I will not add a THC on this project because the working area is not really big so it's not needed here.
Stepper motors will be High torque Nema 23 for X and Y axis and nema17 for Z axis .
For the torch , i'm not sure at this point if i will use a floating head or an inductive sensor to detect the material .
Updated : May 2nd 2017
I take the decision to use I a floating head instead an inductive sensor , because inductive sensor is too expose and can be parasite by plasma arc .
Floating head picture :
Wiring is done .
Some pictures ... first video coming soon
I come back to this project with some mods , ( i add a second stepper on the X axis and some other small enhancements).
First moves :
new picture :![]()
First cut , this project is finally finished
All plates you need ..
Dragon Plasma cutter
Build in 'Plasma Cutter Builds' published by mytechno3d, Oct 8, 2018.
Frank Verheyen, hety, Will McGuirt and 42 others like this. -
Build Author mytechno3d, Find all builds by mytechno3d
I need a portable plasma cutting table .Inspired by
![[IMG]](proxy.php?image=https%3A%2F%2Fopenbuilds.com%2Fstyles%2Fdefault%2Fxenforo%2Fclear.png&hash=56b92a51ab31a9e517496fb08b55b41e)
