F-Ender-Plus its based on the Ender 3 Pro, but improved: CR-10 hotend, double gear extruder, double z-axis motor, BLTouch I'm increasing my knowledge of how get better 3D printings by calibrating motors steps, leveling the hotbed and z-axis; using a 3mm thick glass...
Ramps 1.4 blows twice, but still working, I think I don't calibrate the Vref of A4988 motor drivers, and the motors are too strong, (1.7 A, for x, y and z axis) and the extruder motor 0.4A, I'll gonna change that, all 1.7A motors, and DRV8825 drivers in the next days. The grid of bed leveling, with some errors, may be the BLTouch sensor is not that accurate, and twice I stucked the hot end, I think with wrong numbers of speed, extrusion, and flow of filament (PLA).
F-Ender-Plus 3D Printer
Build in 'Cartesian Style Bots' published by David E. Flores E., Sep 7, 2024.
F-Ender-Plus its based on the Ender 3 Pro, but improved: CR-10 hotend, double gear extruder, double z-axis motor, bltouch incorporated, hotbed leveling improved strings kit. Most made using local vendor parts, and still I'm increasing my knowledge of how get better 3D printings by calibrating motors steps, leveling the hotbed and z-axis; using a 3mm thick glass...
Never, never print without using a fan in the hotend, in the disipator section, because without that, the filament will melt in the disipator section, and can stuck the extruder.
Ariel Yahni and Mark Carew like this. -
Build Author David E. Flores E., Find all builds by David E. Flores E.
- MIT Licence (MIT)
Need to build my own plastic parts for my prototypes.Inspired by
Ender 3 Pro -
Qty Part Name Part Link Comments 2 Nema 17 Stepper Motor Bracket https://vi.aliexpress.com/item/1005004446382173.html?spm=... Link x2 z-axis motors brackets 1 2020 Profile X Axis 2GT Timing Belt Tensioner https://vi.aliexpress.com/item/1005004701650893.html?spm=... Link X-axis GT2 belt tensioner 1 4Sets DIY Leveling Modules 3D Printer Heatbed Leve https://vi.aliexpress.com/item/1005003244541558.html?spm=... Link Hotbed leveling kit 2 Micro Limit Switch Mounting Plate https://vi.aliexpress.com/item/1005004264932656.html?spm=... Link X and Y axis endstops switches mounting plates 1 X-axis Extruder Back Support Aluminum Plate https://vi.aliexpress.com/item/1005001703248007.html?spm=... Link x-axis extruder plate for 3 wheels 1 DIY 3D Printer Dual Z Axis X Axis Linear Rail kit https://vi.aliexpress.com/item/1005006381320354.html?af=1... Link Plates for dual z-axis 2 Aluminum Profile V-Slot 4040 x centimeter https://naylampmechatronics.com/perfiles-de-aluminio/698-... Link 29cm = 290mm - Base side 1 Aluminum Profile V-Slot 2020 x centimeter https://naylampmechatronics.com/perfiles-de-aluminio/693-... Link 330mm - Top piece 1 Aluminum Profile V-Slot 2020 x centimeter https://naylampmechatronics.com/perfiles-de-aluminio/693-... Link 350mm - X-axis rail 2 Aluminum Profile V-Slot 2040 x centimeter https://naylampmechatronics.com/perfiles-de-aluminio/694-... Link 25cm = 250mm - Base front & back 1 Aluminum Profile V-Slot 4040 x centimeter https://naylampmechatronics.com/perfiles-de-aluminio/692-... Link 35cm = 350mm - Y-axis rail 2 3D Printer Lead Screw Thread 8mm https://www.aliexpress.com/item/1005003312523975.html?spm... Link 2mm pitch, 420mm 8 Aluminum 2020 Corner Bracket Fittings 20x20x17 https://www.aliexpress.com/item/32870543302.html?spm=a2g0... Link angled connectors for frame rigid 1 2m lot GT2-6mm open timing belt width 6mm GT2 https://es.aliexpress.com/item/10000401582873.html?spm=a2... Link This is for move X and Y Axis 2 Micro Limit Switch Plate 6063-T5 Aluminum Plate https://vi.aliexpress.com/item/1005005697052778.html?spm=... Link Plates for holding the x2 endstop switches 2 GT2 pully 20 Teeth 6mm with and 2mm ptich https://naylampmechatronics.com/cnc-open-source-hw/116-po... Link for 5mm bore x and y NEMA 17 motors 2 3D Printer Aluminum Z-Axis Leadscrew Top Mount https://www.aliexpress.com/item/1005002433895910.html?spm... Link Top mount for 8mm threated rod 2 T8 Anti Backlash Spring Loaded Nut Brass https://www.aliexpress.com/item/1005002821324499.html?spm... Link T8 Anti Backlash Spring Loaded Nut Brass 2mm pitch 1 Trianglelab 2021 3D Printer 3D TOUCH SENSOR v3 https://www.aliexpress.com/item/32840691571.html?spm=a2g0... Link BLTouch sensor, for hotbed leveling assist 2 v-slot profile 2040 420mm https://openbuildspartstore.com/v-slot-20x40-linear-rail/ Link 420mm of v-slot profile 2040, both for z-axis -
