ATM this just a concept in Fusion 360.
Its made from all 500mm rails, a few 20x20's, and a few 20,40's to build the frame.
Its got a lead screw bundle kit (nema 17) x 500mm length for the Z-axis.
The table, motors, electronics, and wires will be taken from a budget printer I got started on, purchased off amazon a while back.
I will be using a Bondtech all metal Hotend.
I am not sure if I will be going a direct drive, or bowden. My current printer is direct drive and I love it a lot, but I wish I could rapid faster to points, but the added weight wont allow it. This is the reason for the core XY Build.
I am currently working on a configuraiton that will allow a good low profile XY axis at the top using all Open Build components. I really want to just buy the stuff and put it together and not deal with printing custom parts.
So far it looks like I may not be able to get away from printing custom parts, which is fine, I just wanted the nice added rigidity of all aluminum build.
Also, I have never made an XY machine, so I am trying to figure out how I need to mount the motors and how and where to place the idler bearings for the belt config.
If anyone wants to give feed back, that would be great.
First CoreXY Build
Build in 'H-Bot and Core XY' published by changedsoul, Aug 26, 2017.
First CoreXY. Simple Square build, hopes for faster movements.
Whubbzy likes this. -
Build Author changedsoul, Find all builds by changedsoul
I want a more rigid printer with increased quality -
Qty Part Name Part Link Comments 9 20x20x500mm Rail http://openbuildspartstore.com/v-slot-linear-rail/ Link 4 20x40x500mm http://openbuildspartstore.com/v-slot-linear-rail/ Link 1 NEMA 17 Linear Actuator Bundle (Lead Screw) http://openbuildspartstore.com/v-slot-nema-17-linear-actu... Link 2 Motor Mount Plate - NEMA 17 Stepper Motor http://openbuildspartstore.com/motor-mount-plate-nema-17-... Link 3 Mini V Gantry Set http://openbuildspartstore.com/mini-v-gantry-set/ Link
