Hello guys.
First of all let me say what a wonderfull comunity this is. I've dream of having a cnc for so long and the openbuilds comunity helped a lot along the way.
I have a small desktop 3d printed cnc that i tried to do some upgrades to see if i can improve it but it reached a point that all my efforts were in vain due to the lack of stability (flex wise) of the machine.
I've attached some photos of the old machine.
I'm on the early stages of the build. In the pictures i've upload to the file section you'll be able to see that the Y plates were milled from 5mm PVC foam just to prototype a proof of concept. the next step will be milling the X axis test plate in the same material.
All the plates will be cut out of 10mm and 8mm cast acrylic, but for now and just for testing pourposes it will be 5mm black pvc foam
Due to budgetary constrains, i'm going to use the motors of the old machine aswell as the cnc controler box i've built. I'm using the Nema 17 Bipolar 59Ncm (84oz.in) 2A with Arduino and CNC shield and TB6560 drivers.![]()
Today 16/07/2019
I've started to test the X and Z axis. i've decided that the plates for these axis are going to be 5mm cast acrylic. here is some pics of today's progress.
Today 17/07/2019
So after a few tests with the 5mm pvc foam, i've started milling the Y plate, 10mm cast acrylic.
here is some pictures:
Today 20/07/2019
After some milling i've already assembled most of the machine. here is some pics:
Today 16/11/2019
Since the last post i've been perfecting the machine and trying to learn the much i can about milling. for all pourposes i've finished the project here is some pics
Frezar - Desktop CNC
Build in 'Cartesian Style CNC' published by Fábio Pires, Nov 15, 2019.
This is a small desktop CNC inspired by the Mini OX project. It's designed with the nema 17 motors in mind. It's a 650mm x 500mm machine that it will be used to mill cast acrlic.
kishege, Wilson Intai and H@wk like this. -
Build Author Fábio Pires, Find all builds by Fábio Pires
