Aluminum Square Hollow Tube (38.5x25.5mm) for a frame. Frame dimension is 470mmX392mmX545mm.
Gauthali V2.0 DIY 3D printer
Build in 'H-Bot and Core XY' published by Raju Chohan, Aug 23, 2023.
Nallycat and Mark Carew like this. -
Build Author Raju Chohan, Find all builds by Raju Chohan
In our makerspace we have an industrial grade printer named ‘Tiertime Up300’. Which has a mechanical feature different from our previously built DIY printer. We researched about that mechanical feature. Came up with a question, “How does it work?”. After some research we got the answer that such mechanical features are known as core XY systems. But Tiertime Up300 does not have exact CoreXY kinematics. It just has a similar kinematics to coreXY. According to available resources in our makerspace it seems that we can also build that system. So, we came up with a plan to upgrade Gauthali V1.0 into a core xy 3D printer named ‘Gauthali V2.0’. Besides that we chose core xy mechanism due to its advanced features like high accuracy and faster printing speed.Inspired by
Tiertime Up300, Ender 5 series -
Qty Part Name Part Link Comments 8 8mm SBR linear guide rod https://www.amazon.com/SBR20-200mm-Fully-Supported-SBR20U... Link 12 LM8uu bearing https://www.amazon.com/Linear-Bearings-Bearing-Bushing-Pr... Link 2 8mm Lead screw rod with brass nut https://www.amazon.com/Stainless-Threaded-Printer-Machine... Link 2 couplings to Nema 17 shaft https://www.amazon.com/XMEIFEI-PARTS-Diameter-Flexible-Co... Link 2 623.2ZR model bearing for pulley https://www.amazon.com/Flange-Bearing-Printers-Groove-Fla... Link 0 Link 5 Nema 17 Stepper motor https://www.amazon.com/4-Lead-Stepper-Motor-17HS8401-Plas... Link -
