Here's my Hot Wire Foam Cutter now with updated software and firmware.
Full details are on my website as well as an eBook with plans, instructions and a parts list
How to build a Hot Wire CNC Foam Cutter - rcKeith
The build of the CNC hot wire foam cutting machine isn’t difficult measure twice and cut once as the saying goes. The website has the build instructions, plans and main parts you’ll need as well as the cutting lists. The controller board and the stepper I’d recommend you buy as a kit including the power supply. Loads on eBay, just search for a 4-axis CNC kit. I’ve included all the details of my machine so if you follow this you should be able to build your own.
Hot Wire 4 Axis CNC Foam cutter
Build in 'OTHER BUILDS/PROJECTS' published by rcKeith, Aug 26, 2024.
This build uses drawer slides and thread rod to create foam wings and fuselages by passing a hot wire through the foam which makes very accurate shapes. I built a Radio Controlled SuperVC10 using foam but did have a cnc machine then so I had to make many templates to guide the hot wire. This inspired me to build a cnc hot wire cutter. Works really well and have made several RC models with it now
hety, Ariel Yahni, Stephen Yorkj and 9 others like this. -
Build Author rcKeith, Find all builds by rcKeith
Hot wire cutting by hand is OK but requires many templates which take time to make. So I built this CNC hot wire foam cutter to eliminate the templates. I always wanted to build a CNC machine but never though it possible. If I can do so can you.Inspired by
Youtube seeing what was possible. -
