INTERFACE Mounting System
The Interface magnetic mount is a simple mounting solution
As we love the Interface as a great addition to our shops and machines it quickly became apparent that we needed a simple mounting solution to move it up off the work space and into its own location.
With a few parts and a little time you can have this really nice mounting system for your Interface.
Get your Interface Mount Parts bundle here!
- Build Video -
3D Model
Download
Grab your INTERFACE Mount Here!
Build in 'Circuit - Software Project' published by OpenBuilds, Mar 26, 2021.
A simple build that helps you to mount the OpenBuilds Interface to the front of your machine.
Peter Van Der Walt likes this. -
We really needed this as it really helps to keep the Interface handy but mounted out of the wayInspired by
INTERFACE Pendant -
Qty Part Name Part Link Comments 1 Magnet bar https://amzn.to/2WldHgo Link Affiliate Link - This is a stick on magnetic bar that works well for an Interface mount 1 Adjustable V-Slot Hinge https://openbuildspartstore.com/adjustable-v-slot-hinge/ Link 1 9mm Aluminum Spacer https://openbuildspartstore.com/aluminum-spacers-10-pack/ Link This spacer goes between the arms of the adjustable hinge 1 Drop In Tee Nuts https://openbuildspartstore.com/drop-in-tee-nuts/ Link This drop in teenut allows you to connect the hinge to the V-Slot on the machine 2 Low Profile Screws M5 x 8mm https://openbuildspartstore.com/low-profile-screws-m5-10-... Link These screws allow you to connect the hinge to the V-Slot 1 Tee Nuts - M5 https://openbuildspartstore.com/tee-nuts-m5-10-pack/ Link This teenut allows you to connect the hinge to the V-Slot holder piece 2 End Cap https://openbuildspartstore.com/end-cap/ Link Add one to each end of the V-Slot holder piece. 2 Self Tapping Screw https://openbuildspartstore.com/self-tapping-screw/ Link One for each end cap. *Important make sure to hold the V-Slot firmly in a vice when adding screws 1 V-Slot 20x20 https://openbuildspartstore.com/v-slot-20x20-linear-rail/ Link Cut to 80mm 1 Low Profile Screws M5 x 20mm https://openbuildspartstore.com/low-profile-screws-m5-10-... Link This screw replaces the one in the adjustable hinge 1 ALL PARTS BUNDLE https://openbuildspartstore.com/interface-mounting-kit/ Link Here you can grab everything you need (with the exception of the magnet) in one bundle 0 Link
