Unfortunately I do not speak English as well as I would like. So I will not write alot, sorry. But I will add a lot of pictures. Some explanations anyway. Lautr3k is not a "RepRap project," it is a custom build, I'm too lazy to document as necessary. In addition I have to draw my future CNC and many other projects... But if the community want Lautr3k as it is, it belong to him.
Specifications
Print volume : 320x320x260mm
Print speed : > 100mm/s
Price : ~ 700$ *1
*1 : for the main mechanical parts, not including : shipping costs, plastic parts, wiring and control board.
Build Manual (90%)
http://reprap.org/wiki/Lautr3k_Build_Manual
Feel free to correct / complete the wiki. Thank you.
Build Videos from Carl
https://www.youtube.com/playlist?list=PLutvd6j8oY1ErEjcr0ZwqSWGJqilaBHCk
Changlog:
- 05/08/2014: Add Todd US BOM.xlsx
- 04/29/2014 : Add Carl X-ends STL's Updates
- 01/16/2014 : Add missing parts to the BOM (12 x Aluminum Spacers, 18 x Mini V Precision Shim, Mini Hyena v2, J-Head, 2 x 40mm Fan, 1 x 30mm Fan, 3 x Mechanical Endstop)
- 01/26/2014 : Add 2mm motor spacer.stl , STL's.zip and replace skp file.
- 01/21/2014 : Dirty upgrade on the extruder (- extruder flange - dirty upgrade.stl, extruder idle.skpr - dirty upgrade.stl
- 01/21/2014 : Print at 100mm/s
- 01/16/2014 : Add missing parts to the BOM (4 x 605ZZ bearings, 4 x step motor coupling)
- 01/08/2014 : Print at 60mm/s
01/08/14 - Print at 60mm/s - Layer height 0.2mm
01/21/14 - Print at 100mm/s - Layer height 0.2mm
Video : https://www.dropbox.com/s/0x2wr5d6r9plb33/2014-01-20 15.57.30.mp4
We really need a new extruder has this speed !
Youtube
http://www.youtube.com/playlist?list=PLCh576YHZdLiz2qncLdCMhoJjwfZvK4Xj
Photos
Lautr3k RepRap
Build in 'Cartesian Style Bots' published by skarab, Feb 12, 2015.
A 3D printer without belts, a print volume of 320x320x260mm, obviously the V-Slot as linear guide! and a maximum of printed pieces.
Greenish_Apple, manululu, pek and 11 others like this. -
Build Author skarab, Find all builds by skarab
For the fun to learn new things and because i find my Prusa i2 not sufficiently precise.Inspired by
RepRap, MendelMax, Aluminatus, and many others -
Qty Part Name Part Link Comments 2 10 start 25mm pitch fast lead screw and nut http://trinitylabs.com/products/10-start-25mm-pitch-anti-... Link 200$ (2 x 100$) 1 V-Slot 20 x 20 x 426mm http://openbuildspartstore.com/v-slot-20-x-20mm/ Link 10$ (1000mm) 2 V-Slot 20 x 20 x 430mm http://openbuildspartstore.com/v-slot-20-x-20mm/ Link 10$ (1000mm) 2 V-Slot 20 x 40 x 480mm http://openbuildspartstore.com/v-slot-20-x-40mm/ Link 13$ (1000mm) 16 Mini V Wheel Kit http://openbuildspartstore.com/mini-v-wheel-kit/ Link 52$ (16 x 3.25$) 16 Low Profile Screws M5 x 40mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 5.50$ (2 x 2.75$ - 20 Pcs) 8 Low Profile Screws M5 x 25mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 5$ (25 Pcs) 10 Low Profile Screws M5 x 10mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 4.50$ (25 Pcs) 86 Low Profile Screws M5 x 8mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 18$ (4 x 4.50$ - 100 Pcs) 8 Low Profile Screws M5 x 6mm http://openbuildspartstore.com/low-profile-screws-m5/ Link 4$ (25 Pcs) 1 Profile B-type slot 6 - 20 x 20 x 430mm http://www.motedis.com/shop/Slot-profiles/Profile-20-B-Ty... Link 2$ (430mm) 2 Profile B-type slot 6 - 20 x 20 x 440mm http://www.motedis.com/shop/Slot-profiles/Profile-20-B-Ty... Link 4$ (2 x 430mm) 2 Profile B-type slot 6 - 20 x 40 x 430mm http://www.motedis.com/shop/Slot-profiles/Profile-20-B-Ty... Link 11$ (2 x 5.50$ - 2 x 430mm) 2 Profile B-type slot 6 - 20 x 40 x 520mm http://www.motedis.com/shop/Slot-profiles/Profile-20-B-Ty... Link 13$ (2 x 6.50$ - 2 x 520mm) 2 Acme lead screw and nut http://store.makerstoolworks.com/motion/z-axis-lead-screw... Link 37.9$ (2 x $18.95) 1 Heated Bed MK2 Set http://reprapworld.com/?products_details&... Link 44$ (Temporary solution. Looking for a bed 300x300mm.) 4 Axis Couplers - 1/4in to 5mm (pair) http://trinitylabs.com/products/z-axis-couplers-5mm-to-1-... Link 20$ - 4Pcs (2 x 10$) 4 605zz Ball Bearings http://trinitylabs.com/products/605zz-ball-bearings-pack-... Link 17$ (10 Pcs) You can find cheaper elsewhere. 2 NEMA17 Stepper motor 1.8 degrees step / 4.8 kg/cm http://reprapworld.com/?products_details&... Link 34$ (2 x 17$) 2 NEMA17 Stepper motor 1.8 degrees step / 4.08 kg/cm http://reprapworld.com/?products_details&... Link 27$ (2 x 13.50$) 4 Nylon Insert Hex Locknut 5mm http://openbuildspartstore.com/nylon-insert-hex-locknut-5mm/ Link 0.60$ (4Pcs) 4 Nylon Insert Hex Locknut 3mm Link 5 Tee Nuts (25 Pack) http://openbuildspartstore.com/tee-nuts-25-pack/ Link 22.50$ (125 Pcs) 0 Drop In Tee Nuts http://openbuildspartstore.com/drop-in-tee-nuts/ Link optional, but very useful for adding upgrade quickly 22 M3 x 10mm Link 4 M3 x ??? Link Depending on the thickness of your y-plate. 12 Aluminum Spacers 1/4" http://openbuildspartstore.com/aluminum-spacers/ Link 3.60$ (12 x $0.30) 18 Mini V Precision Shim http://openbuildspartstore.com/mini-v-precision-shim-8x5x... Link 3.60$ (18 x 0.20$) 1 Mini hyena v2.0 for 5mm shaft http://shop.arcol.hu/item/mini_hyena_5mm_cr Link 17$ 0 J-Head Mk V-BV https://www.hotends.com/index.php?route=product/product&a... Link 57$ (+7.50$ for 1.75mm) 2 40mm Fan - 12V Link 1 30mm Fan - 12V Link 3 Mechnical Endstop Link -
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.openbuilds.com%2Fdata%2Farticle_images%2Fl%2F0%2F379.jpg%3Ft%3D1389473134&hash=363aff1520cd2a3ee84f70750561a1f5)
