M10CUBE PICO CNC. A Universal Controller ? · Discussion #18 · grblHAL/RP2040
Software work is under way, while waiting PCBs from fabrication factory to come.
WIZcube
Build in 'Circuit - Software Project' published by m10cube, May 12, 2022.
An attempt is to be a Unified Modular Controller based on M10CUBE platform. For GRBLHAL and MARLINHAL applications. HAL porting is under way 1 - WIZnet Pico Clone W5100S-EVB-Pico 2 v- 6 X StepStick. Not sure about the sixth driver, (Pico pins limitation) . External connectors for larger drivers 3 - Opto - isolated spindle PWM. 4 - HMI 5 - I/O on diferent modules and Ethernet 10MBPS communication. Patches will be written to GRBLHAL for Ethernet I/Os (Interrupted).
Team project members, Olivier Gaillard of Denmark and Vasilis Vorrias of Greece
Build Author m10cube, Find all builds by m10cube
- CERN (CERN-OHL1.2+) Open Hardware Licence
To experiment with a 6 Axis Modular CNC and 3D printer controller and Ethernet 10MBPS communication between modules -
