For details on electronic and software, please refer to the Laser V buildlog of Robert Hummel.
-2015/2/5: Add the parts list for a 500x1000mm build.
Much4 - LaserV printed version
Build in 'Laser Cutter Builds' published by skarab, Feb 5, 2015.
By following the way of Robert Hummel, I drew a version of its exellent Laser V to use NEMA17 and easily printable parts.
Nittn Warshne, Kados, hety and 73 others like this. -
Build Author skarab, Find all builds by skarab
Laser V from Robert Hummel - http://www.openbuilds.com/builds/laser-v.226/ -
Qty Part Name Part Link Comments 1 V-Slot - 20x20mm - 1000mm http://openbuildspartstore.com/v-slot-20mm-x-20mm-linear-... Link Y - Axis 1 V-Slot - 20x20mm - 500mm http://openbuildspartstore.com/v-slot-20mm-x-20mm-linear-... Link X - Axis 1 V-Slot - 20x40mm - 1000mm http://openbuildspartstore.com/v-slot-20mm-x-40mm-linear-... Link X - Axis base (2x480mm) 12 Mini V Wheel Kit http://openbuildspartstore.com/mini-v-wheel-kit/ Link 1 GT2 Belt - 3 meter http://openbuildspartstore.com/gt2-2mm-timing-belt/ Link (X = 1x650mm) + (Y = 2x1150mm) = ~3m 3 GT2 Pulley - 20 Tooth http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pu... Link 3 Nema17 Stepper motor http://openbuildspartstore.com/nema-17-stepper-motor/ Link 12 M3 x 10mm Link For fastening the stepper motors. 16 M3 x 15mm Link For fastening the endstop and tighten the belt clamp. 12 M3 Washer Link For fastening the stepper motors. 16 M3 Nut Link For fastening the endstop and tighten the belt clamp. 4 M5 x 6mm - Low profile http://openbuildspartstore.com/low-profile-screws-m5/ Link For fastening the endstop mount and flag. 23 M5 x 10mm - Low profile http://openbuildspartstore.com/low-profile-screws-m5/ Link For fastening the 90° frame brackets, and the belt clamps. 1 Copper module with laser diode http://stores.ebay.com/dtrlpf/ Link Select the desired power (1w - 3W), Leads and G2 lens, without a driver. 1 FlexMod P3 - Analog modulatable laser diode driver https://innolasers.com/shop/index.php?id_product=11&a... Link
