- MULTI - Z - ADD ON -
FOR THE L E A D 1 5 1 5
Get your Multi Z Today
Once again, OpenBuilds takes it to the next level with the Multi Z Add-On
We are putting the power of production in your hands!
This Add-On rivals what's only been previously available on commercial CNC machines.
Cost effective solution to double and even triple your workflow!
"In the same amount of time it takes to cut and carve a single project you could have three using this duplication method!"
The Multi Z addon takes full advantage of the extremely ridged X axis of the LEAD 1515 CNC machine that incorporates a double C-Beam Linear Rail system as well as precision lead screws coupled with a tension system for the absolute maximum in performance.
Bringing all these elements together with the ability to produce up to 3X the outcome and you have a
high-performance large CNC platform that is on par with industrial production levels.
The Multi Z Add-On is a game changer. It's stepping out ahead of the rest taking the hobby cnc market to a new production cnc standard!
Multi Z2 Double Z Gallery
X 23” x 2 (585 mm x 2) Y 49” (1250mm) Z 3.5” (90mm)
Multi Z3 Triple Z Gallery
X 15” x 3 (390 mm x 3) Y 49” (1250mm) Z 3.5” (90mm)
_____________________________________________________________
DOCUMENTATION
OpenBuilds® Triple-Z Add-on
OpenBuilds® Double-Z Add-on
Multi Z LEAD Machine Addon
Build in 'OPENBUILDS MACHINES' published by OpenBuilds, Feb 7, 2023.
The Multi Z adds multiple Z axis to a LEAD CNC Machine allowing it to cut and carve 2 to 3 times the amount of projects in the tame it takes to make just one
Luoies, Peter Van Der Walt, Luigi400 and 4 others like this. -
We designed addon to help customers who are making with their machines, produce more without the added cost of a new machine and more time.Inspired by
LEAD CNC Machine -
Qty Part Name Part Link Comments 1 MULTI-Z ADD-ON bundle https://openbuildspartstore.com/multi-z-add-on-for-lead-1... Link Part Store Addon Link
