Custom Build CNC with redesigned Gantry Plates
1500x1500 mm Project CNC with C-Beam rails
The project has many more Solid V-Wheels and is double belt driven!
New Custom CNC with C-Beam Rails
Build in 'X/Y Table Style CNC Mill' published by Goran crno, Apr 20, 2016.
Hello all, wanted to share my custom build that I planed to do. My idea was to drill foam blocks to make molds for my projects. The CNC will be 1500-1500mm with a higher Z-Axis. So I redesigned the Gantry Plates that will be cut out at some other place. I hope you can share your opinion on my project.
the Gantry Plates are redesigned so I have a higher Z-axis
Ted Moyer, cawa and Martin Banas like this. -
Build Author Goran crno, Find all builds by Goran crno
CNC to drill higher Foam Parts/Moulds
