OXzilla will be a 3ft by 3ft Router/mill that will take advantage of some larger 8020 extrusions I recently purchased on Ebay. The heart of it will be the large, heavy gantry that is built up from two 15 series 3" x 3" extrusions, stacked and joined together with 8020 join plates and the 1/2 thick plates that are used for the side plates.
The linear slides used on the gantry will be the 8020 UHMW bearings. This will be a test of these slides, testing durability. I'm trying these after conversations with engineers at 8020 and a lot of research on the many CNC forums. According to 8020, the issue most have with these bearing seem to arise from improper adjustment or overloading. While I was assured that the 3" wide bearings would to adequate, I'm going to utilize a 6" wide upper bearing on top.
The 1/2" side plates will be married to a 3" x 3" x 1/2" aluminum angle that the 20mm bearing blocks will be bolted to. These will ride on a 20mm fully supported rail that will be bolted to the lower frame.
OXilla - a 3ft x 3ft CNC Router/Mill - Goals are strength, power and speed
Build in 'CNC ROUTER BUILDS' published by stargeezer, Oct 14, 2017.
This will be an ongoing log as I build this machine. Name change by popular demand - at least a couple of us. :)
Michael.M, Garrettcompston and Joe 90 like this. -
Build Author stargeezer, Find all builds by stargeezer
This machine is being built to replace the Shapeoko 2 that I recently completed. I find the Shapeoko to be a good learning platform, but the small size of the extrusions tend to be very flexible after I upscaled it to the 3 sq. ft. size I needed for the work I want to do with it. I did upscale the steppers to NEMA 23 425inoz. and the spindle motor to a 1.5kw water cooled 3ph. unit with a VFD. I confess that the added weight of the upscaled motors are most likely causing some of the flexibility problems, so I may be my worst enemy with the Shapeoko, so I hope that Godzilla solves these problems.
![[IMG]](proxy.php?image=http%3A%2F%2Fi1284.photobucket.com%2Falbums%2Fa579%2FLarry_Kruzan%2F3ce911c0-a1ce-4fee-8f99-b2fc2ab674f2_zpsnmsph72h.jpg&hash=3736c4be6289f406909d4fabe9402103)
