Knock up for a customer, I cannot detail the application yet but working out how to mount OpenRail to a 19" rackmount was a proper lightbulb moment.
Rackmount cabinets normally have a 2 fixing strips (left and right) in the plane of the front panel which forms a lip for securing the item. And another running in the plane of the side, to mount a sub cage to.
Salvaged 19" rackmount, OpenRail inside! Bed 450 sq.
The top of this box has is open with the equivalent of the front panel fixing strips.
Powder fed, sequential layer deposition.
Stainless steel base plate inside a powder tub. The tub is quite shallow for this application.
Insulated
Rear perspex cover
Top cover
Front sliding door - powder loader.
Rackmount + OpenRail
Build in 'Powder Style Bots' published by Bobnet, Apr 11, 2014.
OpenRail attached to a 19" rackmount 15U box.
LOGIC STUFF... make_contact (rod touches powder surface) when load_sensor == threshold_value then switch relay transformer contact_relay 100A @ .25 seconds lift head
Gunshow likes this. -
Build Author Bobnet, Find all builds by Bobnet
Standard Sizes
