      1 votes
      [​IMG] [​IMG]
      Inspired by the original openbuilds C-BEAM, I wanted to make a more compact and rigid version using 15 mm linear rails, aluminium profiles and aluminium plates. The footprint is about 365x280 mm that makes it fit perfectly on a desk.
      Dimensions:
      380 mm width
      500 mm height
      430 mm depth
      Travels:
      X axis travel = 180 mm
      Y axis travel = 150 mm
      Z axis travel = 80 mm
      Table:
      Lenght = 180mm
      Widht = 150mm
      Structure:
      4040 alumnium profile
      8040 c-beam profile
      Axis:
      15 mm linear rail
      8mm ACME lead screw
      Spindle: Makita RT0700C
      Electronics:
      GRBL Shield + 3x Nema 17
      Next step:
      Build an enclosure
      alejoh90, yukuz, manakawari and 17 others like this.
    I wanted to build a smaller and more rigid version of the Openbuilds C-Beam that might be capable of milling aluminium precisely.
    Openbuilds C-BEAM
