After getting my Routy build done, I needed to build something bigger. Then I saw Kyo's Sphinx build and knew I wanted one!! I contacted Chris for a set of 2" extended plates, which were a great price and the craftsmanship is second to none! Placed an order with the Openbuilds.com crew, who do an outstanding job, for most of the other parts I needed. Then finally I went on Amazon for the Raspberry Pi, Arduino Uno, wire and barrier strips.
Thanks to Kyo's great documentation, I had everything put together pretty quickly. I'm currently running wires, but then it will be starting on the controller box, and then some cutting!
First movements!!
Sphinx XL/R7
Build in 'Cartesian Style CNC' published by Hisha, Jun 26, 2017.
A 1000mm x 1000mm Sphinx/R7 build.
Build Author Hisha, Find all builds by Hisha
C-beam Sphinx -
